Results 1 to 20 of 21
Thread: high volume water pump issues?
06-07-2011 #1
- May 2011
- 19
for a little background, the car is a 1986 Z28. TPI fueled 383, griffin 2 row radiator, derale 4000 cfm dual fan w/shroud, 160* t-stat, air dam is in place, radiator sealed agaisnt core support and open area between rad and grille filled in so air can only enter radiator. im running a high volume water pump, and i had heard from someone a while ago it can cause an engine to run hot by the coolant not staying in the rad long enough. my car will stay at 170 idling with both fans on when its 90* out. however, when cruising down the highway (75 mph, 2k rpms) with the fans off, it will run about 200-210* it cools off if i switch the fans on while driving. when i got home, i felt the tanks on the rad, and the cool side wasnt all that much cooler than the hot side, maybe only 30* i was thinking before it was a fueling issue, but there is no signs on of it running lean, especially at high rpms. should i go with a standard volume water pump?
1986 Camaro Z28. TPI fueled 383. 430 hp, 466 lb ft. Still a work in progress but driven often
A third gen that does more than go in a straight line
