Results 1 to 20 of 29
06-07-2011 #1
Questions about smoothing firewall
Hi all! I have the front end off my 'Bird and plan to smooth the firewall soon. I will have no wiper motor (car will never see damp pavement or leave the garage if threatening rain) and will have the a/c lines that I will be adding exit on the pass side under the fender. I've seen a few companies that offer complete firewall sheet metal that is smoothed, as well as a forum member who had one custom cut. My question is this. Should I have the existing firewall cut out and weld the new one in it's place, or have it welded in over the old with beads of adhesive between old and new (this what the member who had one custom cut did)? Also, if I do weld the new one over the old one, will it interfere with the fender alignment (added sheet metal spacing) as the fenders have one bolt that goes into the firewall itself. Lastly, if I go with a Wilwood booster, would you remove the existing threaded (4) bolts that the stock booster bolted on to, or would you remove them (leaving 4 holes for mounting) and have the master bolt through into nuts on the interior? Just trying to plan and want to learn from those already in the know!
Do what's right,not what's easy
