Thread: cheap rear disc setup for cheby
New to Pro-Touring
- May 2005
- jackson, Tn.
- 44
has anyone seen the set-up that asphalt/ dirt track guys run for their rear brakes? I was clued in a couple days ago and apparently a complete rear disc set-up for a 10 bolt, 12 bolt or nine inch ford can be had for less than 200.00. I was very skeptical and had to go look for myself. It is very trick and track proven. I'm gonna give it a shot and see how they work. the only down side I see is that they use a multi-fit " hat" that the rotor is bolted to, to save weight. Everyhing else is pretty much standard. The caliper brackets are weld-on for the older GM caliper or the newer metric caliper. If anyone would like more info. gimme a buzz and I can hook you up with more info., and some contact numbers.........
In the immortal words of Hannibal Smith " I love it when a plan comes together".
