      Houston, Tx
      Rear Spring Pad Necessary?
      I'm using a 8.5 10 bolt rear in my 69 Firebird which has the universal type spring perches welded on and 2 u-bolts going over the rear axle and through the original shock plate. When I first assembled this I used the rubber multileaf spring pads, but they seem to have split. To I "NEED" a spring pad between the persh and the spring or can I make a solid mount without the pad?
      Thanks!
      Drew
      Drew H.
      Houston, Tx
      After sifting through about 3 pages of historic threads I found they are not absolutely necessary.....guess I'll pull them out tomorrow night.
      D
      Drew H.
      May 2002
      Northern California
      ahhh no
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Central CA USA
      With that type perch no pad should be used!
      Feb 2003
      Houston, TX
      I ditched those rubber leaf pads a long time ago. After doing a few hard launches at the track, they would split and make my axle get out of line. Tossed those suckers and never looked back!
      Tony
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      Houston, Tx
      Thanks! Exactly what I needed to know!
      I guess playing the other night breaking in the new 2800 stall converted split the pads. ;)
      http://firstgenfirebird.org/show/closeup.mv?CarID=642
      Drew H.
