      Apr 2010
      LS3 Wiring Diagram
      I have a L76 crate with an LS3 top end (and a mild cam) that is going into a 69 firebird.
      Can someone help me out by providing this diagram? I pulled the following information off of the ECU.
      On the ECU, it says:
      GM Racing
      GM# 19258268
      Gr. 3.670
      GM Performance Parts LS376
      It's wired to mate to a T-56 Transmission
      With the harness is a pretty hefty fuse box. I couldn't find any telling ID numbers on the fuse box. It has four relays, a couple of 50 amp fuses, a couple of (i think) 30 amp fuses, and a bunch of ancillary fuses. (I'm trying to mate this harness to a Painless harness.)
      After being left out in the sun for a few hours, it appears the paper inside the fuse box has faded, rendering it un-readable. Does anyone have a photo of this?
      Full res photo:
      http://farm4.static.flickr.com/3222/...0b288052_o.jpg
      Walla Walla, WA
      PM me with your email address. I have a .pdf wiring diagram that might help if you're patient.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Feb 2012
      Any chance in you sending me that diagram as well. I have a LS376/480 GMPP harness kit & the fuse diagram under the cover came faded.
      Walla Walla, WA
      Sure, PM me your email address.
      Walla Walla, WA
      Fuse panel layout for GMPP 376/480 wiring harness:
      Eastern Virginia
      Does anyone know how to take the PCM/ECM connector housings apart to add/remove pins from it? I want to add one for the reverse lockout but haven't figure out how to get it apart.
      Scot
      86 Monte SS
      Metamora, Illinois
      Quote Originally Posted by Samckitt View Post
      pm sent
