      Sep 2008
      California
      B&M Quicksilver shifter help
      I have this in my 75 Formula.. like it lots but had an issue the other day..
      I have looked everywhere for this info and cant find a diagram that shows the parts or how to remore/replace things. Plenty of install diagrams I already have.
      For the most part it's pretty simple.. But I had an issue after getting it back from the paint shop getting some chips and other issues repainted. I think they couldn't figure out the shifter and hammered on it possibly... Dunno..
      Might have been a coincidence.. But after a shift or two after picking it up, I couldn't get it down into Drive.. I drove it home without touching the shifter..So I took it out and apart and got it to go back into drive anyhow.. But now.. The shifter is sloppy loose and It clear I didn't do something right.. (or it is in fact broken, and a part is gone or something..
      1) How do you get the pin out that holds the Handle / arm on..?
      2) It would be super helpful if someone look to see how the big spring on the passenger side is fitted? Seems now that I put it back together I may have not set that spring in correctly/ I took it off and looked again.. And there are not too many options.. There are not that many moving parts, and I do not know what I screwed up. It almost feels like the spring is not on correctly..
    Tags for this Thread
