      Jul 2010
      reverse lockout solenoid
      Can anybody help me out? Should the pin on the reverse lockout solenoid move in at all if it is not energized?Mine does,it does but takes a little force.I dont think it should,which is why it will shift into reverse without being energized.Is there a adjustment that I dont know about? The tranny is a t56 w/B&M shifter.Thanks for any info
      May 2002
      Southeastern WI
      In my experience you can get them into reverse without engergizing the solenoid. It takes a little force and you definitely know you are doing it. I wouldn't think you really could go into reverse by accident.
      Jeff
      Jul 2010
      Thanks for the info.I guess whats bothering me is i don't feel a differnce in going into reverse with the reverse solenoid energized or not powered up-what do you think? Thanks again...Curtis
      May 2002
      Southeastern WI
      I hooked mine to energize off the brake light switch. When you have the key on and the car off you can hear the solenoid click when you step on the brake.
      Jeff
      Jul 2010
      thanks for the info VanB,i'll wire mine up like that and see what happens..wish me luck
