Ride height - Are the springs seated in the pocked correctly?
The coil springs should have a model number inprinted on them, but I don't know if they will be visable when set up in the car. Only way to know for sure would be to drop them out if you can't identify them.
Have you lightened the front end (aluminum block/radiator/battery in trunk, etc?) What are you using for shocks?
