      Feb 2003
      St. Louis, Missouri
      Floor Pan install.
      I've managed to over-think my way into a roadblock. The following pic is the current state of my floor pan install in my 91 Camaro. I've installed them with 1/2" of overlap from the inside of the car (read: replacement pan is sitting on top of the original floor by 1/2" on all edges) It's mostly tacked in at the moment and I'm afraid that if I grind the welds down any further I'll burn through the original floor. The overlap is causing me not to be able to grind the welds down to achieve a "flush" looking result. I would like to know what the "correct" procedure is from this point. Add more spot welds to grind every thing flush? Seam sealer? What does everybody do from here? If I prime this, it'll look like chit.
      Rick Butterfield
      Jan 2009
      Jacksonville Florida
      The floor should be fitted flush with no overlap and butt-welded,then ground smooth.There is no other way around it if you want smooth suface from both sides .
      If you want a quick,simple install, use metal bonding adhesive or punch/drill holes about every inch around perimeter and weld the holes,then use seam sealer
      Do what's right,not what's easy
      69 Firebird
      71 Cuda
      98 Supra 6speed white APU
      98 Lexus GS400tt widebody
      Elite Custom Body
      Stefan B.
      Feb 2003
      St. Louis, Missouri
      So a panel flanger or take the time to fit it perfectly and butt weld. I'm not a quick and simple guy, if it deserves to be done, it should be done correctly. I suppose I should've done a bit more research. I've only ever seen it done this way....guess I wasn't watching the right people.
      Rick Butterfield
