    Results 1 to 9 of 9
      Aug 2009
      Illinois
      Carb for 383 stroker
      Trying to get some suggestions on a carb for my new 383. Has iron Vortec heads, 10:1 pistons, Performer RPM intake, Comp Cams .454/.454 cam, manual tranny. Car is a 65 LeMans that will be mainly street driven. Any and all advice welcomed.
      NH
      A 750 would be a good starting point but what kind of use are you planning?
      SHAKER TUNED SOLUTIONS
      May 2011
      Wyoming
      670 Holley Street Avenger for a street driven car. Looks good, easy & simple to adjust or dial in. Vacuum secondaries, quick-change spring, etc.
      Roger
      1967 Camaro, ZZ3/M20, work in progress.
      1957 F100, 4 wheel independent, 4 wheel disc, 32V 4.6, collecting parts.
      2001 Silverado, 11.59at 113 MagnaCharged L33.
      Mar 2011
      Ca
      a little more info is needed to get an acurate assesment, what is the intended rpm (shift point), but judgeing from what you listed above i would say 650 to 750 would be where you want to look, i'm not a fan of vacuum secondaries in a heavier car so i would use a double pump carb, holley makes a 700 cfm DP carb that would probably be perfect for you.
      Gainesville, GA
      I prefer mech. secondarys in a manual trans application. 650cfm would be my first choice. Enjoy!
      Eric Evans
      Aug 2009
      Illinois
      Thanks for the replies. Right now i'm leaning towards the Holley 650 Ultra Dbl Pumper. Local speed shop guy can get me a good deal on one since he would like to check one out for himself. Figure if he's willing to give me a deal to use my car as a test mule why not.
      Feb 2011
      So CA
      I have about the same engine and I runa 780 street avenger and the engine loves it!
      Dec 2010
      Fredericksburg, VA.
      The tendency is for guys to over carb engines and in truth a smaller carb will give you better throttle response. I think your 650 is a good choice. In point of fact, I'm running a 600 which worked good to 7000rpm back when I was drag racing.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Jan 2007
      CT
      This is good advice
      A correctly jetted 650 double pumper with mechanical secondaries is the right carb.
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
