    Results 1 to 9 of 9
      NJ
      Derale fan controler
      I have a Derale dual fan, I bought two controllers. they have a separate plug in coolant sensor and harness. I don't want to run two sensors. Can I run one controller for two fans, or can I use one sensor and splice that off to the two adjustable relay controls?
      thanks
      Derale has an adjustable fan controller that controls two fans and has one sensor - is that the one you have? I have one and use it for two fans with one sensor. It was only $42 from Summit I think. Just make sure it has enough amperage capability for the relay for the fans you are using.
      70 Mach I, dry sump & lots of mods
      70 1/2 Z28 project car
      NJ
      I have two of those, but the fan says 50 amps ( I assume total of the two ). The controller says 25 amps per relay. I got two because of that fact. It has a separate sensor for each, I'm hoping to splice one sensor into two controllers. It has a two wire sensor with the same color wires, I don't know what wire does what. I think it is just a simple circuit ( on and off ) the controller does the work. Do you know how much your fans are pulling?
      I have two fans that say they draw 7.5 amps ea continuous and recommend a 30 amp fuse. Each flows 1650 cfm.
      NJ
      the 50 amps sound high to me, I'm going to test them myself and see what they pull
      thanks for the help
      Sydney, Australia
      Country Flag: Australia
      Use the Derale's controller relay to run two external relays - one for each fan...eays fixed.
      I had no issues run dual fans with a Derale controller on my 77 T/A...good unit. I used the spare aircon input connection on the controller to run run an over ride switch to turn the fans on anytime I liked.
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
      NJ
      Your the man, never thought of that, I like it, solves the problem. It has the option to run an external switch or use the wire for a/c fan control. No a/c so a switch will be used.
      thanks very much
      NJ
      That's how I did it, we'll see how it works soon when I fire it up.
      Cornettsville, ky
      i run the radiator probe one on dads truck with dual lt1 fans
