      Aug 2010
      2010 camaro pump and Ricks Tanks
      I have the new vaporworks tank by Ricks hot rods.....Very nice! My question is about the fuel pump connector. I have the part number 92202097 priced out but it is very expensive for not needing the whole harness. Has anyone been able to locate just the connector and pig tail vs. the whole harness at 90$ a shot?
      Any leads on part numbers or phone numbers would greatly be appreciated.
      Chuck
      Dec 2009
      San Diego, CA
      These are the parts I used for a 2007 silverado fuel pump module that i think are the same as the 2010 camaro module. The are the individual pieces for a GT 280 series connector.
      http://www.mouser.com/Search/Product...ey829-12191235 - seals
      http://www.mouser.com/Search/Product...ey829-15326004 - pins
      http://www.mouser.com/Search/Product...ey829-13521459 - housing
      Aug 2010
      Thank you Very Much!!!
      Newbury Park, CA
      That connector will not work. Been there, done that.
      If you are running the module with the 4th-gen mechanical regulator as supplied from Rick's then I can supply a complete harness. The harness has a OE plug for the module, a quick-disconnect plug so that the wiring can be disconnected near where the wiring passes through the aft trunk floor, and 5' of GXL wire past the quick connect. PM me if you are interested.
      Phoenix
      I would just get the one from Carl. That's what I got and it's plug it in and go.
      Erik
      https://www.pro-touring.com/showthre...without-a-name
      Camaro LS2, T56, 12 bolt, C6 Z06 brakes, Rushforth Super Spokes, ATS Spindles
      2006 Chevy Trailblazer SS
