      Apr 2008
      Penfield, NY
      68 bird trunk finished
      I just want to say thanks to sam hatco for giving me the inspiration to refinish my trunk> It was worth all the work!
      birdboy
      bowling green,ky
      Nice!
      Apr 2007
      Huntsville, Tx
      Great job! Looks terrific.
      Sam
      69 Firebird convertible T/A pro-touring custom, Now LS1/T56 six speed, 3:42 Eaton posi, 18" Iforged wheels, 04 GTO interior.
      www.fquick.com/SamHatco
      Jack of all trades, master of none.
      Melbourne, FL
      What material did you use ???
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Apr 2008
      Penfield, NY
      Thanks sam..I did copy yours, except I made the bird out of mdf and made it recessed. I heard someone say that copying is a form of flattery. I couldnt have done it without the inspiration and pics from your build!! And the material is black marine vinyl, which i purchased from joanne fabric and I used a spray contact cement to attach to the mdf.. I also made a remote control electric trunk with a key fob...its was so easy. Put your electric trunk latch in and wire it to a remote control unit. make sure it is a single button with a momentary on off control so it turn on and off with one push of the button. I learned the hard way and first used a remote with a two button on and off remote..well I forgot to hit the off button after I opened the trunk and burnt my 179.00 modo electric latch. I was able to save it by attaching and external door lock actuator..works great. These remote kits can power anything that has 12 volts to it. Lights etc.
      birdboy
      Apr 2007
      Huntsville, Tx
      Cool!
      Sam
      Rustburg, Virginia
      clean looking trunk...good job
