    Results 1 to 10 of 10
      Engine bay progress.
      Gotta get the photo off my phone, but I've pulled the engine and transmission out of my car so I can take it to the body shop to have the firewall fixed. Very excited, as once this is done, it will let me get back to some reassembly and progress forward.
      Going to have the DSE fill plate put in and the firewall repainted black, maybe the dash. The dash is currently body color, but the main gauge panel didn't get painted so it's black so I need to have that fixed too. Trying not to get crazy with paint right now, just getting it to where I can have the body painted later without too much to disassemble again.
      Does anyone have any tips on what other small holes to fill in? Leaving the stock steering column hole, brake holes, blower motor etc and using a Painless Harness that goes in the stock location but I want to make sure I get the rest of the small holes done up. I'll be eliminating the stock throttle assembly and using a Lokar cable. Any tips for that?
      I have one spot one the side of the car that's covered by the fender, that the metal is so thin, it's got holes in it but was painted over by the last shop. I can see light coming through the paint if I look in the blower hole... ARGH.
      Here's hoping to not end up in paint jail!
      Thomas
      Spare Change: 68 Camaro, 300hp/350ci, 700R4
      Templeton, CA
      I had to drill a new hole for he Lokar setup. You'll have to do that with the pedal linkage inside all set up to get the right height for the hole.
      I should be doing my firewal next week. No fill plate, just cleaning it up. I've already welded some of the smaller holes up. Heck it looked like swiss cheese! lol
      Here's a link to a thread on Camaros.net with some help with holes in a firewall. http://www.camaros.net/forums/showthread.php?t=153286 You'll recognize the OP.
      Robert
      My sloooow build thread...https://www.pro-touring.com/showthre...hlight=Orngasm
      "If happiness is in your destiny, you need not be in a hurry."
      If I can only convince myself of this!
      Thanks!
      Thomas
      This has been a surprising mental hurdle for me, I'm feeling good about progress once this is done even though I know I'll have some challenges.
      Thomas
      Okay, sprayed some cheap rattle can gray on the firewall. I think I'm going with a gray firewall/engine compartment. Need to figure out how far up the cowl area to go.
      Got an appointment at the shop for after Memorial Day so I'll get the car in then.
      Thomas
      Off to paint tomorrow, wish me luck.
      I've got a few photos on my phone that I'm trying to get uploaded.
      Thomas
      Hole the last shop hacked for the VA install. I had the Sure Fit kit for a factory air car, they weren't supposed to touch the kit, and should have let me know what they had to do if they did. I would have sent it back and used the money elsewhere. Thank goodness for the DSE plate!
      Holes that I'm filling marked F, the two for the A/C evap canister you can't see because of the gray paint. A couple are just from firewall plugs for the carpet/backing inside and I'm filling the stock throttle mount holes and a few small ones.
      Should I fill the holes for the factory wire loom tray? The black plastic trough up by the top of the firewall. I thought I'd leave it, but I want it to look good. I'm filling in where the MSD box was mounted.
      Also, are there supposed to be holes for a weather strip or something that runs along the top of the firewall? I believe there is.
      Thanks!
      Thomas
      I'm not sure what #1's are, but #2 are for the factory wire trough.
      Also, what's the best way to get the cowl tag off, intact? I'm not sure I'll put it back on, but it's got several layers of paint and is hardly readable. I want to save it, and I can put it back on later. Non restoration, so I'm not worried about the correct attachment method etc. Just want it to look nice.
      Thomas
      Going to the shop. Little bit at a time...
      Decided on semi gloss single stage, rather than gray, for touch up issues.
      Thomas
      Well, bad news... the firewall was finished but the edges of the DSE panel has grinder marks in it around the edges from grinding the welds down! Argh... So it's still in the shop so they can fix it. The welds on the inside need dressed as well.
      All the holes were filled and it looks good other than that.
      Thomas
