      Fenton, MO
      New Exhaust (video inside)
      Well I finsiehd up my Single Exhaust the other day. I will say I am impressed with the sound of that "Super 40" mufler.
      In this video the idle is a bit high but you get the idea.
      http://www.odiesgarage.com/Nova/imag...st/exhaust.mpg
      Ontario, Canada
      Sounds pretty good for a single exhaust. What do you have for an engine? headers?
      Ken
      My other car is a Vega.
      Red Deer, Alberta, Canada
      Why did you go single?
      Sounds pretty good being a single though. 2.5inch exhaust?
      -Matt
      Matt
      Instagram: Cst_koon
      Fenton, MO
      The engine is just a SBC 350, Vortec HEads, Mild Comp Cam, and a 750dp Holley. Has full legenth Headers. The system is a dual 2.5inch off the headers into a single 3inch muffler.
      It will in the end get a tailpipe that will exit behind the drivers side rear tire. Why single exhaust? Its was something diffrent, this car has had everything from straight pipes to an H, X, so why not a Y pipe
      Ontario, Canada
      Quote Originally Posted by ChevyIIMan
      I agree....."why not". It sounds plenty good enough, and probably has enough capacity for your engine combo. You combo has the smoothest sounding 40 series muffler I've heard so far. I suspect all of the exhaust going through the one muffler may have something to do with that.
      Ken
      Beaufort, SC
      I ran a single exhaust on my 95 z28 with a 383 (although a bit larger), I tucked the tailpipe up where it turned down right at the bottom of the bumper to make it a little more stealthy as well. Single tailpipes work perfectly fine so long as the area is enough for the engine to breath!
      '72 Chevelle- 4 wheel 12" Discs, Konis, Hotchkis springs (shortened an extra coil up front), 17" Cragar Soft 8's with 245's in front and 275's in back. ---STILL IN PROGRESS---
      Fenton, MO
      Thanks, yeah I figure its enough for my combo right now, and with a tailpipe it should have some people guessing...
