    Results 1 to 9 of 9
    Thread: QA1 Coilovers
      Chicago
      QA1 Coilovers
      Ready to pull the trigger on QA1 coilovers for my 69 Camaro. I am trying to decide on a spring rate of 450 or 500lbs. I have a big block with aluminum heads, front end weight 1940lbs without driver. Any advice on selection would greatly appreciated. Thanks
      Dante'
      Mar 2010
      My 2 cents is if you are going to lower your car significantly you should run the 500 lbs springs. This will prevent or minimize wheel rub issues when hitting bumps. I installed 500 lbs springs on my 1967 firebird convertible and it rides perfect.
      Front - QA1 w/Speed Tech a-arms
      Rear - QA1 Prodigy 4- link
      Chicago
      Thanks. That helps me alot.
      Dante'
      Mountain Springs, Texas
      I think you should consider 550. I have 550 on my AME subframe with an LS1 and the ride is very nice, not harsh.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Phoenix, AZ
      Give Rob a call he can help you out with your coils for a great deal 480-748-2000 and I agree on the 550LBS
      Chris Fesler
      St George Utah
      definatly 550 lb
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Chicago
      Guy at QA1 recomended 500lb.
      Dante'
      Oct 2010
      Santa Ana, CA
      Is the front ride hight stock or lowerd?
      Chicago
      I want a lowered stance.
      Dante'
