      Sep 2007
      Denver
      Throttle body size advice
      I currently have a used 1550cfm Accel throttle body set up to use for my Gen 7 system. I have never fired up the motor to know how it's all going to work. I have been thinking the big cfm may not give me the best throttle response since street driving is mostly what will be done when I'm finished. I have the opportunity to purchase a smaller ( and new) throttle body which flows 1375cfm and has 4 throttle bores vs 1 I have now. I'd love to hear what you guys may suggest.
      Engine is crate 572 (620hp)
      David Beckstrom DVM
      Jan 2010
      Long island NY
      iam thinking with the large throttle boy its going to be a little jerky due to size but it you have it i would give it a shot you have a TPS correct? Drive by wire?
      70 Mustang fastback 428 sb
      Sep 2007
      Denver
      Yep...all the goodies. Tps,I AC, etc
      David Beckstrom DVM
      Nov 2004
      Colorado
      does the smaller TB have a progressive linkage?
      Sep 2007
      Denver
      Yes. It is progressive linkage
      David Beckstrom DVM
      Nov 2004
      Colorado
      I'd say go for the (slightly) smaller TB for the progressive linkage. A 100% VE 540 cid engine requires a 1000cfm carb for 7000 rpm, so with the 1350 TB I'd say you are good. If your engine is smaller than 540 you're even safer.
      Sep 2007
      Denver
      It's a 572. I know throttle body size isn't directly related to carb sizing for obvious reasons.
      I can't find much info about rules of thumb if not math equations to make the call. Too small of course a problem but how critical it is above that I haven't a clue.
      David Beckstrom DVM
