Results 1 to 13 of 13
Thread: Problems with Billet Hinges
04-28-2011 #1
- Feb 2006
- 478
I have recently run into a snag with my Eddie Motorsport Hinges for my 67 GTO. The hinges are actually 64 chevelle, but that is what they sell for the 64-67 GTO. The problem is, when the hinges are installed, the bolt holes for mounting the hood are 11/16" to narrow. This is both in the up and down position. The hinges are really nice and the work flawlessly, but that is too much difference for me. The hinges are actually too close together. If they were outward to far, you could shim them in, but that's not the case. EMS agreed to take them back, but I really want some cool hinges.
I measured the dimension of the hinge from the fender mounting surface to the centerline of the hood bolts and it is about 1.93 inches on one hinge an about 2.03 on the other. So I thought I would call Fesler and see what their hinges measured. Well, for some reason I could not get them to tell me. I have no idea why. If I could get the measurement and be convinced they were the ticket, I would order the $800 hinges today, but nope, they said too bad.
What gives? Is this some kind of top secret info that you have to have a security clearance to get? Is this the secret to it all? If this info leaks out, is it going to blow the hood hinge market wide open?
Alex Godsey
Somerset, KY
Pro Touring 67 GTO
461 Pontiac Power
04-28-2011 #2
Banned
- Aug 2003
- Orlando, FL
- 8,745
You GTO uses 64 Impala hinges, not 64 Chevelle
04-28-2011 #3
- Feb 2006
- 478
Well, that could be the problem I guess. I just ordered 67 GTO hinges and EMS said they are the same a 64 Chevelle. I am pretty sure Fesler said the same thing. But, they wouldnt give me any measurement to go by.
Alex Godsey
Somerset, KY
Pro Touring 67 GTO
461 Pontiac Power
04-28-2011 #4Directly from the invoice of my Fesler hinges. These fit absolutely perfectly on my '66 GTO build. Original steel GTO hood on the car. I could not be happier with the hinges.
FBH-908 POLISHED Billet Aluminum Hood Hinge with Stainless Steel Strut. **Fits 1964
Chevelle, 1964-1967 GTO, 1963-1964 Impala, 1963-1964 Chevy Full Size cars and
1963-1965 Chevy II
*****Some modifications may be necessary on applications other than the 1964 Chevy
Chevelle
***** 12 lbs shipping weight****
66 GTO- Steel Hood
04-28-2011 #5
- Feb 2006
- 478
Well, not that i am not used to that working with a Pontiac, But I am not paying $800 for hinges and having to modify anything. If they want to charge premium price, they need to provide a part that works. You claim they work well though, so sounds like they have a good product there that fits multiple applications.
I have a Ring Bros set on order. After talking to Mike at length, I think I understand some of the issues that made these hinges not work. Hopefully I'll have good luck with these. Also, Mike Ring and Tammy Walsh were great to work with and were very very helpful.Alex Godsey
Somerset, KY
Pro Touring 67 GTO
461 Pontiac Power
04-28-2011 #6
