Results 1 to 12 of 12
Thread: Wilwood seals leaking
04-27-2011 #1
Well I added Wilwood front kits to the Camaro/IA2 Pontiac motor drag project and it has been sitting while I work on other things but the Wilwood seals have been weeping grease moisture down on the rotors. Will this resolve once it starts turning when rolling more? New seals on the new hubs and no scoring on the spindle.
1978 Black Trans Am 455 Edelbrock heads [email protected] through mufflers on pump gas
1965 GTO project car
2004 Pulse Red GTO
04-29-2011 #2No ideas??
2004 Pulse Red GTO
05-01-2011 #3Call Wilwood? Not sure of anything else. Not ignoring you.
05-01-2011 #4Just figured with all the brake folks heresomeone would have had this happen, even on a factory rotor. Either bad seals and I need new ones or since it sitting and not spinning the grease around it should be fine once moving seems the two logical options. The bearings look like factory #s so I assume Wilwood uses factory sized seals also.
2004 Pulse Red GTO
05-03-2011 #5Wilwood Tech out there? Called and left a message and no call back yet on the tech line.
2004 Pulse Red GTO
05-03-2011 #6
- Jan 2006
- Oregon
- 1,773
