      Aug 2008
      Houston, TX
      ZZ383 Optimal Thermostat
      Hello guys,
      I have a zz383 motor in my 70 Camaro. The motor makes great power (369RWHP/412RWTQ), so now I'm trying to improve MPG and around-town driveability.
      I know that the GM manual recommends a 180 degree T-stat, but recently I have been thinking about a switch to a 195 as I am well aware that engines are more efficient and more responsive at higher combustion temperatures.
      Also, because of my very stout cooling system, the engine will hover around 170 on the freeway because of the full-time airflow. This seems a bit low for me as I happen to do a lot of long highway treks. Hopefully the 195 will increase these temps to at least 180, allowing the oil temperature to reach its ideal point of 210-215.
      What do you guys think about this?
      Thanks for your help. Cheers,
      Matt Bezkrovny
      Who is wise? One who learns from every man... Who is strong? One who overpowers his inclinations... Who is rich? One who is satisfied with his lot... Who is honorable? One who honors his fellows" - Ben Zoma, Ethics of the Fathers, 4:1
      Henderson,NV
      Matt, you are fighting two variables. I agree that most engines like a warmer temperature. They are more efficient and it's easier on the parts. However, if your engine has a carb, it can cause heat soak and less power due to the inlet temperature. Modern fuels are NOT designed for carb's anymore. They boil easily especially at altitude.
      Todd
