      Dec 2010
      Gaston, SC
      Camaro/Chevelle Spindles
      I am looking into a disc brake swap for my 64 chevelle. I currently have drums all around, and I found a kit for C4 rotors and C5 calipers. The kit says it requires spindles with a 5/8" upper anchor bolt. I'd rather not take my brakes apart to measure mine, so I was hoping someone could tell me if the upper anchor on the 64 spindle is 1/2" or 5/8". Would a 68 Camaro drum spindle have a 5/8" upper anchor? Thanks again, guys!
      Milan
      1964 Chevelle SS
      Dec 2002
      Lost Wages, Nevada
      Why not get ATS spindles and take care of multiple problems all at once ?
      Dec 2010
      Gaston, SC
      They're just a little bit out of my budget.
      Milan
      1964 Chevelle SS
      Marshall , MO
      With out pulling it out, I don't know of any other way to tell. If you do a full C5 swap the adapter can be made out of plate and does not require the machined adapter. The C4/C5 will give you a few more wheel options but most of your custom wheels will fit or can be ordered to fit C5 brakes.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Dec 2010
      Gaston, SC
      I'd prefer the C5 setup, but I just got wheels for my car in December. The boss would not approve a new set just yet.
      Milan
      1964 Chevelle SS
      Dec 2010
      Gaston, SC
      I think I'll try to find a used set of spindles just to be safe. Probably lead to less downtime that way, anyway.
      Milan
      1964 Chevelle SS
      Oregon
      1964 A-body should be 1/2-20 upper mounting boss assuming they're original.
      Tobin
      KORE3
      It's what I does.
      Dec 2010
      Gaston, SC
      Thanks. I found a set of 68 Camaro drum spindles on fleabay for 99 cents plus shipping. They should be here in a few days.
      Milan
      1964 Chevelle SS
