    Results 1 to 20 of 27
      Jan 2007
      CT
      Home made splitter project begins!
      So this is my attempt at a home made splitter / spoiler. I purchased a plastic lower air dam from a late 90's GM application. I then won on Ebay a front splitter used from a NASCAR application.
      The Splitter
      The air dam was close the the 1967 Camaro factory contour. The entire middle section was close. From the center line of the factory spoiler moving left and right the two migrated from each other about 1/4 away on each side so. I'll need to change the bend but that will be later on.
      Here they are over one an other
      The over width of the spoiler needs to be trimmed by 16" so I took 8" off the straight sections where they are not lining up.
      The result a new splitter that is as wide as the left and right measurements of the lower front fender extensions where the factory support bars go.
      I need to get my buddy's plastic welder next.......
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
