      Dec 2010
      SE Florida
      Backfiring popping on deceleration
      Just got my car back after having a cooling system installed and after taking it for a ride it seems to be backfiring and popping out of the exhaust when letting off the gas. It is a 598 BB with a holley 1000 carb. Any ideas? Plugs and wires are good.
      Jan 2007
      CT
      Was there any exhaust work done recently? I have had a backfire / popping when i fixed my x pipe and missed a section welding it up. I know hearing a slight exhaust leak over a 598 BB may be hard. How are the collector gaskets?
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
      Dec 2010
      SE Florida
      No exhaust work done recentley.. Everything is tight. The engine was running on for a few sec's after shutting off but after I turned the idle down it seems ok now.
      Livermore, California
      Too much timing? Too rich?
      Dec 2010
      SE Florida
      Timing is set right, plugs Have a tan color so it's not running rich..
      Dec 2009
      Jetting...
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Mar 2011
      Ca
      have you checked for vacuum leaks?
      Dec 2010
      SE Florida
      was a leaking exhaust manifold gasket..problem solved
