      May 2008
      Electronic Speedometer / Cruise Question
      I have an electronic speedometer and will be also installing a Rostra Cruise control.
      Can I use the same sender for both the cruise and the speedometer?
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Erie, PA
      What electrinic speedo are you intending to use?
      Besides of the sender input, my Autometer speedo had a separate OUTPUT for a VSS signal which I used for the Cruise...
      Andreas
      www.fgmcc.com
      May 2008
      I am using a Stewart Warner, I just ordered the sender that they sell, they state it will run 2 speedo's so I am guessing it will also run a cruise control.
      Jul 2010
      the motor city
      Yes you can split the signal. Its just pulses so it will work just fone
      mark
