      Bay Area
      Chevy Check Engine Codes HELP PLEASE!!
      I have a 1996 Cheyenne V6/5 speed that has been flashing the "check/service engine light" for awhile and today I had the mechanic at work scan it. He came back with several codes but I wasn't there for him to explain them to me. Can anyone break down the codes for me?
      1.P0102 Mass Air Flow Sensor or Volume Air Flow Sensor
      2.Circuit Low Input (not sure if this is part of the MAF sensor)?
      3.P1406 Undefined Code?
      4.P0700 (PD) Transmission
      5.Control System P1192 (PD) (not sure if this is part of the transmission)
      I'm not sure if these are in correct order, I'm going off of what he wrote down and how he listed them. Thanks in advance.
      Jose (Joe)
      1963 Nova SS Convertible
      1978 Malibu LT1/4L60E
      1978 Malibu Stock
      2007 Harley Dyna SB
      69LAnd
      circuit codes are usually a bad fuse or wiring test for the maf that you have a ground an 12v+ the last wire would be the signal wire ,but with that many codes I would check the fuse box for bad fuses or corrotion
      p0102 circuit fault code maf
      p1406 circuit fault egr
      p0700 apears to be a tranny circuit code too
      p1192 same
      so just look at your wiring first and make sure your batt terminals and grounds are ok
      Rick M.
      hMMMMMMsss....
      1969 Camaro real RS SS DSE LS3 6M TWiiN TURBO in the make!(taking forever!!)..any donations apreciated hehe
      Bay Area
      Fuses all look good. There is no fuse for the tranny in the fuse panel (5spd). Wiring and terminals all look good at the battery.
      Jose (Joe)
      1978 Malibu Stock
      2007 Harley Dyna SB
