Thread: Cfm?
04-14-2011 #1
Cfm?
CFM is cubic feet per minute. So when speaking of carb's thats cubic feet of air correct? I am guessing its sort of like a MAF, higher CFM carb means more fuel so it isn't running too rich or too lean correct? Thanks, Bradley
~Bradley~
04-15-2011 #2
- Jan 2010
- Elk River, MN
- 676
You're partially correct, cfm on a carburetor simply applies to the rated flow of the carburetor, it has nothing to do with how lean or rich the mixture is. Basically your need for flow in a carburetor is based on your entire motor system, and is directly related to the amount of air that the motor will flow, so for example a stock 350 V8 will require a smaller carburetor than an equivalent 350 that's been equipped with aftermarket high flowing heads, a high lift cam, a single plane intake, and headers, because the latter moves a lot more air. To adjust the mixture (rich/lean) you can change jetting to suit your particular motor, bigger jets to richen the mixture, or smaller jets to lean out the mixture.
This covers carburetor tech pretty well:
http://www.strokerkits.com/tech-info...cfm-rules.html
-mattMatt Peterson 84 Monte Carlo - Sold :( | 99 Corvette Racecar | 2001 Z06 Daily Driver
https://www.pro-touring.com/showthre...ng-Bertha-Back
http://ls1tech.com/forums/conversions-hybrids/1499192-84-monte-5-3-build.html
https://www.pro-touring.com/threads/...rvette-Racecar
04-16-2011 #3Thanks a bunch. Is it the same with blow-through carbs? I havent seen any below 600cfm. Do they use specific type jets or???
~Bradley~
04-18-2011 #4
