    Results 1 to 1 of 1
      USA1
      reverse lights wiring
      Hi all,
      After installing a set of headers in my '69 Camaro, I had to remove the reverse lockout linkage up to the steering column. As you know, this also causes the backup lights to constantly be turned on.
      I know this issue has been solved before many times, so does anyone have a painless way of altering the wiring so that my backup lights only come on when I'm in reverse?
      Any recommended switch I can install on the trans (it's a Muncie M21)?
      How should I disconnect it at the steering column?
      Any re-wiring tips?
      Thanks in advance,
      Mike
      '69 Z/28 V0105DZ, D80, X33, DNE4+1
      '98 Z28 M6
