    Results 1 to 20 of 28
      Tuning help/suggestions
      ive got a 67 camaro with a BBC, and ive gotten it running deciently. but i am having problems on hard accelleration. it likes to stumble i guess would be the word.. Instead of nice smooth acceleration upon an idle to WOT smash it bogs down/hesitates a little before taking off. i have tried a few different pump cams but so far it seems best with the pink cam on the #1 position. i have the full cam kit but dont have a chart to compare whats what with. i have gotten it a little better. but can't seem to get rid of it. timing is roughly 25* initial with an advance of around 36*, but it doesnt appear to be timing. i have # 72 jets in the primarys and 80 in the secondarys. plugs look ok, maybe a little on the dark side but not black. im looking for suggestions as to where to go from here. carb is a demon 850 by the way. it almost seems like it runs outta fuel on those WOT smashes because if i roll into it gradually or if i pump the throttle it seems to be fine. thanks for the help and or sugestions
      Nov 2003
      Paradise, Ca
      Try a bigger squirter.
      -Matt
      Thats the next step. what would the next size be if i have a 31 in there. im not sure how the incriments run, and am not sure where to find out. thanks
      after looking around is the squirter # the diameter in .0xx"? if so they seem to go 32 and a 35
      Nov 2003
      Paradise, Ca
      I've never measured one, but yeah, I believe that's how they're sized. They're available in 28, 30, 31, 32, and 35 (for gas).
      There's also two different styles of squirters...the normal one that you have, and a tube style. Just like the name implies, the tube style expels fuel out of extended tubes. I dunno what the actual net effect of this style squirter is, but they can be usefull for fine tuning.
      If you have 31's now, I would go to a 32pri and leave the secondary alone. If that doesn't do it, bump the sec up to a 32. If it's still not enough, go 35pri...etc.
      If you still need more fuel from the accelerator pump after going to 35/35, you'll need to step up your accelerator pumps to 50cc pumps, as opposed to the 30cc pumps you have now. Unless you have a LOT of motor, you won't have to do this.
      Also, keep in mind that when you do find a squirter combo that works, they will more than likely work even better with a different pump cam. It's a never ending battle it seems, but it's so worth it in the end.
      Allways check your pump actuating lever clearence after changing cams.
      I recommend one Advil and two Ibuprofen for sore backs.
      -Matt
      The "dog-leg" boosters are 90-degree and promote a better fuel signal at idle, while the annular style are more for racing (4150 series). Also, what PV(s) are you running? Too much lift at the pump cam will drain the accelerator pump too quickly as Matt said-you will need a bigger kit (50cc) and then go to a larger squirter, then you'll most likely need to go upstairs with the jets, too...say around a 76 and an 84 sounds nice. You definitely have a lean stumble. -Jabin
      [email protected]
      I believe the demon comes stock with a 6.5 PV. thats whats in there. what needs to be done for the larger accelerator pump kit? is that just a direct swap?
      well heres where im at now. ive played aroud with it and i have #35 squirters both front and rear. pink cam on the # 2 position and it still bogs. do i try a 74 primary jet, or go for the larger, 50cc pump.
      Is it posible that its getting too much fuel. would that cause a stumble like this?
      my set up is
      402 BBC bored to 414, .060 i believe
      AFR magnum 305 heads
      236/242 .612 lift cam
      11.0:1 cr
      26 deg inital 38/40 advanced
      thanks for the help
      Nov 2003
      Paradise, Ca
      How much vacuum do you have at idle? You need to get the power valves situated before you go any further.
      Example: You have 5.5" vacuum at idle. You need 3.5 power valves.
      You have 10.0" You need 8.5
      Man it's been too long, will somebody please verify this?
      -Matt
      not sure, ill have to borrow a guage and find out. does the guage just hook onto a vacuum port on the carb?
      Nov 2003
      Paradise, Ca
      Yessir. Look in your Demon instructions and it'll show which port to take the reading.
      -Matt
      thanks matt. by the way what do i want to see for readings?
      Nov 2003
      Paradise, Ca
      That depends on all kinds of things, but as just a guess, I'd be looking for 8" ±2".
      -Matt
      matt, i got a vacuume guage and it reads right around 6" at idel. i played around with the jets and bumped up to 74 and 84 and now the stumble is way less noticible but its richer then hell
      Nov 2003
      Paradise, Ca
      One thing at a time dude! Never make two changes at once, or you'll have no idea what change effected what. If it's not detonating, don't mess with the jets anymore until you've got everything else dialed.
      6" is fine, but you need to change the power valve to a 3.5. with a 6.5 power valve and 6" of vacuum, that means the power valve is constantly open, dumping fuel in that you now can't control.
      Fix that, and then re do your idle mixture screws. How many turns out it takes on the mixture screws will tell you roughly where you're at.
      -Matt
      ok thanks. im gonna put everything back and recheck the vacuum. i believe i took the reading with my old set up. but i will double check. thanks again
      Nov 2003
      Paradise, Ca
      Change the power valve first.
      Is there anybody watching and learning from this? Speak up now if you are because otherwise, I'm gonna work with kman over the phone or IM's or something to speed up the process.
      Also, where are you from kman? If there's someone local to you that can help, that'd be a huge bonus. This stuff is difficult long distance.
      -Matt
      matt, thank you. i appreciate your help. i just looked and see power valves ranging from 1.5-10.5. how do you know what to use is there a formula? or is it just years if trying different combos? i will pick up a new P.V. in the morning but might be busy till this weekend. i will get back in touch though. thanks a million
      Nov 2003
      Paradise, Ca
      Power valves open when manifold vacuum drops below their rating. So a 3.5 will open (and dump fuel) when manifold vacuum drops below 3.5".
      You size power valves two full numbers under what vacuum you have at idle. That way, it's far enough away so that any dips in vacuum won't tickle the power valve, and it also gives the idle circuit a chance to do it's job without dumping extra fuel the instant you touch the throttle.
      (you have) 6" - 2 = 4 (round off to 3.5)
      -Matt
      Chicago - western burbs
      Quote Originally Posted by Matt@RFR
      Yeah, I was, but didnt want to butt in. I'm going thru the same off idle stumble in my 455 Pontiac. I've been steping thru things like Kman is, just not as diligently. I'd like to hear how things progress, but if you guys take it off line thats fine...I'll get thru it.
      Rubes
      Nov 2003
      Paradise, Ca
      We'll keep it here then. No biggie. Feel free to butt in! No farting though.
      -Matt
