    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 48
    Thread: I Killed it!
      Jun 2002
      Santa Clarita Cal,
      I Killed it!
      So my worst fears have been realized, last night I got the stud girdles mounted valves adjusted again and all seemed ok, took it for a spin and it started making that crazy noise again like the flywheel was hitting something, it also started to misfire, when I first heard this at RTTC I thought maybe it was a bent pushrod hitting the head as it was rotating but they have all been replaced, I’m going to pull the engine now and see what’s going on inside, if it’s obvious and a simple fix I will put it back in, if it turns out o be more serious it will be a new motor.
      I’m considering an LS3 or all Aluminum BB 522, opinions please! The BB would be much easier to do, not sure on cost differences yet.
      Damn I paid for Delmar this weekend!
      RSK68
      Rick Klein
      Feb 2011
      Hills of Anaheim
      That sucks to hear. Hopefully it is indeed a simple fix.
      Matt - 1970 Chevelle
      www.street-demons.com
      Feb 2006
      If it sounds like the flywheel hitting something, why did you replace the pushrods and put stud girdles on?
      Check the flywheel?
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      Jun 2002
      Santa Clarita Cal,
      Because I had bent quite a few pushrods at the last event I was at, it only now sounds to me like the flywheel is hitting something, doesn’t mean the flywheel is hitting something! just a description of the noise I'm hearing, when I pull it apart I will know better.
      RSK68
      Rick Klein
      Dec 2009
      The misfiring - along with the other noise - is what concerns me. Hoepfully it's not something serious Rick!
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Sunny Florida on the Suncoast
      I hope that is a simple fix Rick. Then again it is a good reason to make changes.......twin turbo LSx anyone.....:D
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
      Newbury Park, CA
      Did you do a compression check Rick?
      Jun 2002
      Santa Clarita Cal,
      Carl yes i did roughly 180 on all 8, there is just something very wierd going on, have good oil pressure too!
      RSK68
      Rick Klein
      Newbury Park, CA
      Yank the distributor and confirm if the gear is OK.
      Nov 2001
      St. Cloud, MN
      My brother had the flywheel to torque convertor bolts loosen up once and hit the block edge during rotation. Something like that possibly?
      Jon
      71 Nova LT1/4L60E
      Lawrenceburg, TN
      I know this sounds random but did you look at the tops of the valves? The side just under the rocker arm, I have seen them lighty mushroom and that creates back firing
      Mar 2011
      Ca
      Sounds like you have a problem in the valve train, you shouldn't be bending pushrods. I just lost a lifter and in turn my cam and the way they went it sounded like something tapping on metal, turned out a lifter bridge broke and the lifter spun in the bore and wiped out the cam lobe.
      Sep 2009
      Oxnard, CA
      Rick- Sorry to here about your engine issues... I have something in the shop that I will give you a smoking deal on if your motor happens to be bad!!
      Henderson,NV
      With good oil pressure and compression, it SHOULDN'T be a huge cost to fix. Good compression rules out a bent valve or a broken piston or ring.
      Todd
      Oct 2010
      Vancouver B.C Canada
      Sounds like maybe a valve hanging up or a damaged/broken/very weak valve spring? If its misfiring at the same time as its making noise I cant help but think valve trane. Good luck with it...these things can get frustrating, but there is always an explanation. Are you by any chance running a roller?
      72 firebird , SD performance 464" 455,KRE D ports, EZ EFI,Dougs 1 3/4,3.5" custom oval exhaust,TKO600,Kore 3 C5/C6,DSE subframes,Full cage by Radical Rides(Thanks Dave,Johnny,Campbell,Bill,Lee and Gabby!!)
      Huntington Beach, CA
      Sorry to hear Rick. Need to get that thing fixed and get you out to Buttonwillow. It'd blow your mind!
      Feb 2007
      The Declining Market
      Before you pull it the engine, hook up a timing light to see if the noise is lower end generated or half speed which would indicate upper end problems.
      Dan
      1969 Chevrolet Camaro
      /DSE/SDPC-LS7/T-56/FORGELINE/BAER/VAPORWORX/SPEARTECH
      /DAKOTA-DIGITAL/RECARO/MOMO
      /MSP-FAB/BLACKTECH/
      Jun 2002
      Santa Clarita Cal,
      Long Story!
      This is going to be embarasing, so last wenesday I dropped the car off at a friends shop so he he could install the stud girdles for me as i was running out of time before Delmar, the plan was to pick it up thursday night and load it up in the trailer, he called me thursday and told me he was having a hard time adjusting the valves and if i would come down and help him so he could close at a normal time, so i get there and he's got one side done and is finishing up the other side, i start helping by puting on the valve covers, we fire it up and it sounds fine so i start to drive it home, after about 3 miles it starts making all the crazy noises again %^&# i limp it home and make my post about i killed it!
      So today i start to tear it apart and see a few loose valves maybe .075 gap and then there is one at around 1/4" i'm thinking the worst, i start pulling it apart and notice the rocker nuts are all chewed up on the end that seats on the rocker arm, the comp rockers have a 9/16 diameter countsunk face around 1/16" deep, the original nuts are .540 diameter, the new nuts that came with the stud girdles are 5/8" diameter and were not seating at all but he shure tried to seat them ^%&*ing unbelievable! this is a case of if you want it done right then do it yourself, so tomorrow i'm going to buy the correct nuts and start over! crazy Huh!
      RSK68
      Rick Klein
      Well that's good news right? Sweet
      Sep 2002
      So. Cal
      Quote Originally Posted by rsk68 View Post
      Long Story!
      Ouch! on a positive note..glad to hear it wasn't something more serious..
      I hear ya on doing it yourself.. although I can screw stuff up just as good as the next person. I just try to keep my screw-ups low in cost. Filed under lessons Learned..
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
