    Thread: Oil lines?
      Port St. Lucie FL
      Oil lines?
      So does anyone know what kind of lines can be used to replace the rubber hose that will with stand the heat and oil?
      Kacy
      79 Corvette, 406 SBC, Holley EFI, 700R4
      Aug 2001
      Connecticut
      I've always just used aeroquip braided stainless lines with AN fittings. The new ptfe lined hose is a nice upgrade but requires different fittings than the normal braided.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      follow what the oems do and make up some hard lines with rubber hose only where you need some flexibility. depending on what you are building, you might even be able to find some oem oil lines that will work. Chevy V8's can use truck or Caprice setups for oil coolers, and a lot of early 90's 4X4 Blazers and S10s with a 4.3 came with a remote oil filter that mounts up on the firewall, with an oil cooler mounted in front of the radiator.
      Jun 2006
      NW burbs IL
      I used Gates C5E hose, ( http://www.hoseandrubber.com/PDF/Hyd...ulicTubing.pdf ) they are used on trucks and buses. You can purchase JAC ends that can be attached with hand tools. With the JAC ends you can use either AN / 37* or Auto 45* fittings.
      Matt
      Port St. Lucie FL
      Quote Originally Posted by novaderrik View Post
      The problem was on my 96 s10...I fixed it by trading it in. Wednesday i pick up my 2010 toyota corolla
      Kacy
