    Page 7 of 11 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 LastLast
    Results 121 to 140 of 209
      Nov 2009
      Colorado
      Quote Originally Posted by Samckitt View Post
      Ernesto, I wanted to use an adapter like that for the oil pressure sensor, but I have the Mast oil pan & the area of the pan where that cover mounts is different.
      It has a couple of threaded fittings for a remote oil cooler, and it has a 1/8 NPT fitting on the back side of the pan (red arrow), but the flywheel is sticks out farther than the hole, and no way to put a 90 fitting in it. Mast won't answer me on how to use it either
      I didn't realize that you had the Mast oil pan.. I glad i went with the CTS-V oil pan. TnMonteSS your fitting seems cool though..
      Ernesto M.
      Jan 2010
      LS Monte Oil Pressure Adapter
      Scott:
      This was our soln for my 85 LS Monte SS .....adapter has provisions for the Monte analog gage sensor, an oil pressure idiot light( old "choke" idiot light in Monte stack was retasked), and a sensor to the ecm....tricky part was getting the "clock" right for posn of the analog and idiot light sensor so as to assemble correctly....
Size:  65.9 KBName:  IMG_0267.jpg
Size:  59.0 KBName:  IMG_0268.jpg
Size:  73.2 KBName:  IMG_0270.jpg
      Eastern Virginia
      I like it. Did you make that yourself? I'm having doubts about my method now.
      Scot
      86 Monte SS
      Jan 2010
      I like it. Did you make that yourself? .
      Yes, it's home made.....I'll see if I can find the print if you would like.......
      Eastern Virginia
      I had something similar to that drawn up but couldn't find someone to make it without charging me an outrageous amount. I started with a hex rod, & was going to have a hole threaded in every other side of the hex at the same height, so it would be shorter than yours. And have the hole tapped at the top & threads put on the bottom.
      I feel like the Tin Man from Wizard of Oz. Except instead of singing "If I only had a brain.", my motto is, "If I only had a lathe."
      Scot
      86 Monte SS
      Eastern Virginia
      I'm about ready to switch to the CTS-V pan myself. All the trouble the MAST pan has caused hasn't been worth it.
      Scot
      86 Monte SS
      Nov 2009
      Colorado
      Well i'm sure Mast would get back to you... I do like the way my CTS-V oil pan fits.. I am planning on using the adapter, just finding the plugs have been a mission.. I should've just bought them..
      Ernesto M.
      Eastern Virginia
      Had some brackets cut out to strengthen the lower control arm mount points.
      Going to weld a plate to the surface where the bolt comes through, then weld these plates in place then add a cap to the outside. I think that will make it plenty strong. I may have to make the outside radius larger, gotta compare it to the location of the mufflers on the car now. Not sure I have enough room.
      Scot
      86 Monte SS
      Mar 2010
      Okinawa, Japan
      Good idea, I bought these http://www.tntraceshop.com/1978-1988...01-180201.html before i got the plasma cutter but would have just made them if I had it first.
      Take a look at the upper ones too, might be something to think about while you have the frame off.
      Eastern Virginia
      Yep, I am going to make something like this too for the top.
      Scot
      86 Monte SS
      Eastern Virginia
      So with what I have $ wise in the LS2 so far & the price of the trans I was going to get, I can almost buy this:
      This chassis will include the following:
      6.0L LS2 ENGINE
      T-56 6 SPEED MANUAL TRANSMISSION
      3.42 GEAR RATIO REAR DIFFERENTIAL
      Complete front and rear suspensions
      Manual shifter
      Left & right fuel tanks
      Left & right fuel pumps
      Complete OEM exhaust system
      Emission control unit
      Fuel crossover pipe
      Anti-lock brake system with booster and module
      Engine computer
      Engine harness
      Transmission harness
      Body harness
      Under hood Harness
      Body control module (BCM)
      Under Hood Fuse Block
      Vin matched key fob
      OEM Push Button Electronic Start Ignition Switch
      Air flow meter
      Air cleaner
      Pedals
      Juice Clutch
      Brake lines
      Fuel lines
      Steering column with tilt wheel and intermediate shaft
      Leather wrapped steering wheel (no air bag)
      Emergency brake handle with cables
      18" OEM C6 Chrome Wheels & Tires
      19" OEM C6 Chrome Wheels & Tires
      So if I do that, then my current motor or the one in the chassis will be for sale. I know a ton of work, but how cool!
      Scot
      86 Monte SS
      Mar 2002
      North California
      6.0L LS2 ENGINE
      Manual shifter
      Fuel crossover pipe
      Engine computer
      Engine harness
      Body harness
      Under hood Harness
      Vin matched key fob
      Air flow meter
      Air cleaner
      Pedals
      Juice Clutch
      Brake lines
      Fuel lines
      Scot ,that would be sick! So are you gonna build a Monte or a Vette dude? lol
      Eastern Virginia
      Deleting Duplicate post.
      Scot
      86 Monte SS
      Charlotte
      would you need to lengthen the torque tube?
      2014 Chevy SS LS3 / 4 Door
      Eastern Virginia
      Quote Originally Posted by bonecrrusher View Post
      I don't know for sure until I had parts to measure. From what I found the wheelbase of the Vette & the Monte are both 108", so it's close but may need modified.
      Scot
      86 Monte SS
      Eastern Virginia
      This looks awesome
      Scot
      86 Monte SS
      Charlotte
      is that a 32 ford Chassis?
      Eastern Virginia
      I found it on trifives.com talking about frames with C5/6 Vette setup. No info on it, so not sure what it is for, but it is cool.
      Scot
      86 Monte SS
      Charlotte
      2 words.... DO IT!!!!!!!!!!!!!!
      Eastern Virginia
      Gonna need some help, who belongs to SEMA that can get me cad part files of the front & rear suspension?
      Scot
      86 Monte SS
