      Bolivar, MO
      Which fuel tank should use?
      Ok I am getting the parts together to do a LS6/4L80E swap into my 1972 Chevelle, I am ready to purchase my fuel system. So I was wondering should I use a stock tank with an external fuel pump, or do I should I go with a rockauto or spectra tank?
      I do not have the funds for tank like Rick's but really wouls like one though.
      Tim.
      Good question, I am in the same dilemma. I would not suggest an external tank. I have had starvation problems with this set up. I would love the vaporworx or even the sst Rock valley but am leaning to the new in tank Spectra tank. Anydody know where to get this tank?
      1969 Camaro, GM PP HO 454, Procharger D1-SC, 12 bolt rear end, 3:73 gears, 700R4, Borla XS mufflers, X pipe. Ride Tech Air Suspension and Retrotek Speed EFI. AR S200 wheels and Nitto 555. Wilwood 6 piston with Hydratech boost.
      Apr 2004
      OKC, OK
      rock auto has spectra, we quit carrying them due to starvation issues. As much as I liked the lower priced option of the spectra, the gliches were not worth the negatives. We now currently only have DSE or Ricks available
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Bolivar, MO
      I have not seen the DSE tank. It is not on there website. Mike do you have any more info on it?
      Thanks Tim.
      Apr 2004
      OKC, OK
      Sorry i misquoted, DSE does not have tanks for A bodies, only F bodies. That would leave Ricks, Spectra, or making your own
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Bolivar, MO
      Mike what do you guys get on a Rick's tank? And how is everyone sumping a stock tank? Is there a benifit in sumping it?
      Thanks Tim.
      Mission Viejo, CA
      Depending on the amount of room you have between the frame rails, you might be able to fit a late model Impala plastic tank in the car. I did this on my car. The frame on my car is the same dimension used on the '90-'96 Impala. I picked the tank up at the junkyard with the pickup for $50. The tank is 23.5 gallons. I run a Racetronix harness and Walbro 255 liter pump that fits in the stock location. Works great and looks stock.
      1973 Hurst Edition Pontiac Grand Am: 430 CI of ERL built LS7, Tremec Magnum T-56 6-speed, Global West / Speedtech Suspension, Custom rear coil-over suspension, QA1 double adjustable shocks, Wilwood 6/4 piston disc brakes, Modulare C1 19" concave wheels. Shooting for 625 HP and 20 MPG!
      Bolivar, MO
      Later-A-body, how low does the tank set in your car? I have read some on this install but most say you have to cut in to the trunk pan because of the pump/sending unit sets up in the tank. If you do not cut the trunk then it sets further down, how much further does it set?
      Tim.
