      Jan 2009
      Cannes, France
      Temperature goes up and down.
      My setup is a 350 smallblock, griffin big block alu radiator with an electric fan, CSR electric waterpump, 2 senders placed on each side of the thermostat housing in the intake manifold.
      The temperature goes up and down, it can change 30+ degrees and does it within 10-20 seconds.
      Both my gauges show the same, one is from Autometer and the other from Dakota.
      Changed my 180 degree thermostat to a brand new 195 today just to try something but still the same problem. The old thermostat was a different model than the new one, looks like one with a kind of bypass that I have seen photos of on this site.
      Will an electric pump turn the wrong way if connected wrong?
      How do I choose the right radiator cap? I have one from Be Cool and one from Griffin
      I have an overflow tank from BeCool but it doesnt seem to work that well or maybe it is too small 1 pint.
      Well thats all for now. Thx in advance.
      Jan 2009
      Cannes, France
      Nobody has any ideas?
      Central NJ
      Maybe air in the system. Did you burp it?
      Jun 2005
      Sounds like air in the system, possible a steam pocket is in the system which raises the temp quickly, then it comes back down. I had a similar problem once and cured it by drilling a 1/8 inch hole in the thermostat (hole goes up). Solved my issue.
      Anthony
      http://www.cardomain.com/ride/674663
      '71 Datsun 510, 2jz-gte (Supra TT) engine
      http://instagram.com/supra510
      Jan 2009
      Cannes, France
      Hi Guys
      Will look at the thermostat and see if there are any holes otherwise I will drill one.
      How does the "burping" work?
      Kenneth
      Fontana, CA
      Can be best accomplished through Block filling. When the T-stat housing is off, fill the block completely through the t stat opening. The problem usually comes with air trapped under the tstat when filling via the radiator. Also, filling while warmed up and fluid is cycling will help.
      Nick R.
      Central NJ
      Quote Originally Posted by kenhaw View Post
      Hi Guys
      Kenneth
      You can buy pre-drilled thermos but they are kind of uncommon to purchase. I run a drilled one in my daily and a flow restrictor in my Nova.
