      Feb 2007
      USA, TN
      Bleeding the slave cylinder
      This may be a dumb question but... I have a T56 Magnum with a Camaro LS1 slave cylinder installed in the car. The engine is not in yet. Can the slave cylinder and master cylinder be bleed or will the slave cylinder blow apart if the clutch isn't against it?
      Sep 2009
      Ontario, Canada
      Yes ... if you push the TO bearing & piston back and block it so the piston can't extend it too far (need a block with hole to fit over pilot) ... or are super careful and manually push the slave piston back after each pump of master. Master and hose should be bled before conecting to the slave or you just push air into the slave, i.e. bleed master and hose, push slave piston fully back, connect to hose, crack bleeder and allow gravity feed until you see fluid out bleeder, tighten bleeder, pump master so piston extends 1/2"-3/4" or so, crack bleeder and push piston back, tighten bleeder, repeat until no air bubbles. Tap the slave to help get air bubbles out. Best to hold the piston back to keep the seal square when pumping master ... easier to do it on a bench. I think Keisler has a video showing bench-bleeding of the master & slave.
      Hope this helps.
      Duane
      '74 AMC Javelin AMX
