      recommendations on cooling system
      My motor should be ready in approx. 1 week and would like to get some feedback on cooling. I do not have any cooling problems with the current zz4 motor. I am putting in a 406 600hp small block with 10.7-1 comp.and would like to loose the motor fan and go with the be cool with dual 11" fans. Will this be sufficient? All recommendation would be appreciated, I am concerned about running hot.
      Cooling
      Hey,
      I'm running a 383 Stroker with a/c. I use an Afco aluminum radiator with
      double cores that are 1". Two 10" Zirgo fans.
      I bought the radiator for $185.00 and had two brackets welded on the tanks for mounting.They pull 1500cfm each.
      It cools well. You'll need the extra cooling with the compression.
      Billy
