      Woodbine, MD
      T56 not shifting??!!
      My g/f has a 2004 Mustang Cobra and we recentlly got the trans fluid changed and used the Royal Purple fluid. It has been driven about 2000 miles since the fluid change and now it is VERY hard to get into gear. It seems to happen the worst after the car has heated up some. Any ideas?
      Douglas Lutes
      1988 Monte Carlo SS
      Feb 2009
      Long island, New York
      so when the car is running it doesn't want to shift into any gear? but does it shift into gear when the car is off? my t56 wasn't wanting to shift while the car was running but when i turned it off it would go right into gear. i ended up have to self-bleed the system by opening the reservoir and pumping the clutch while adding fluid, and it worked fine since then. was it royal purple atf with dexron/mercon III ? or royal purple synchromesh, because i have done a lot of reading and found that royal purple synchro mesh adds a lot of wear on the synchros, and that gm factory fluids work really well. i have 4 quarts in mine and it shift like brand new! i hope this helps. -Dom
      Dom Buffa
      Woodbine, MD
      thanks for the info...it was the RP synchromesh. uh oh....
      Douglas Lutes
      1988 Monte Carlo SS
      Oct 2010
      Kansas
      Did the samething in my WS6, drain it out put the GM stuff back in it and it'll be fine.
      US Army Retired
      Desert Storm, OIF 2003 & 2004
      1973 Firebird
      2001 Trans Am WS6
