      livermore ca
      Setting up helwig sway bar
      Just got done I stalling a helwig sway bar on my dads 69 chevelle, I'm wondering what the best way to get it set up just right.ext what length should I have the end links and what position should they be hooked up 2 on the sway bar? Thanks in advance
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
      Mar 2010
      AZ
      You want the bar as close to level as possible at ride height.
      The setting on the rear bar will depend on how your dad wants it to handle and what front swaybar is installed and what the springrates front and rear are.
      IMHO, start in the middle and move it if it doesn't feel right.
      Robert R.
      1988 S10 blazer 5.0L SBC 700R4 body off build.
      1991 S10 Blazer 4.3L too low daily.
      1975 Cutlass Salon currenlty 350/th350
      Stupidity should be painful.
