    Thread: Beehive springs
      Beehive springs
      The comp cams tech guy is suggesting that I switch from a 340in\lb dual spring with damper to a single beehive spring which summit lists as a 130 in/lb spring.
      This is on a full hyd roller setup on a bbc using factory style bbc gen 6 lifters and retainers. Cam is an xe-294-hr comp cam.
      Does this sound right. Comps website seems to be broken at the moment so I can't read up on the beehive springs and how they compare.
      mo
      i have used the on a lot lt-1 and ls-1 engines,they work great and because theres less spring the engine will revs quicker.i like them for those appilcations never tried on anything else yet.
      Thall shall fear no amount of boost, For thy bottle is with me.......
