      Jun 2009
      Central FL
      Porsche idle issue
      Hey guys, my DD is having a little trouble and I'm not 100% sure what it is.
      When the car starts, the idle is really low, 8-900rpm, and has a bad rumble (misfire? 3 cylinders running?), but when the car gets out of idle (the slightest tap of the accelerator), and the car comes right back to life, no loss of power, nothing.
      My Dad told me to do the plugs and wires, and that's what I was originally thinking, but my uncle told me it might be a vacuum leak, which is why I decided to ask here...
      Any help?
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      Long Beach, Ca
      Could be a vacuum leak. Dirty throttle blades? Weak coil?
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      UK London
      My DD is a 996. Just went to my Porsche specialist today with an unrelated issue but as always he got the laptop out first. If yours is a 964 then I'd start with plugs leads and visual inspection first....Loose T/B carb/intake bolts may give you the vacuum issue you suspect...good luck with the P car...
      If things get complex Renlist and Piston heads are good sources of info and P car gurus....
      Jun 2009
      Central FL
      Quote Originally Posted by Procharmo View Post
      I was outside messing with it a few hours ago, the throttle body screw came completely out. Luckily, I was able to find it. Thanks guys.
      Dan
      1968 Camaro v2
      Just North of NYC
      Pelican Parts forum is your best bet for P-car tech.
      westchester county new york
      And an awesome pitbabes thread..just sayin.
