      Jan 2011
      Boston, MA
      Fesler Body Mounts
      Hey guys, I've lurked here quite a bit, but my first post over here. I just picked up some solid aluminum body mounts for my '67 Camaro from Fesler but I'm not sure which way the washers go for the radiator support bushings. There are two for each bushing, one is the same diameter as the body mount, and one is a little smaller. Has anyone used these before? Thanks.
      Jan 2011
      Boston, MA
      And while were at it, does anyone know the torque recommendations for the front, and mid/rear mounts?
      Nov 2010
      Ventura County CA
      You could go by the Global West instructions and use their recommended torque (100ft-lb x 4 and 75ft-lb x 2 radiator)
      http://lib.store.yahoo.net/lib/yhst-...00instructions
      Jan 2011
      Boston, MA
      Quote Originally Posted by TheBandit View Post
      Thanks, I have a copy of the Global West instructions as well as the Speed Tech instructions.
      GW - 100ft-lb x 4 and 70ft-lb x 2 radiator
      Speed Tech - 75-95ft-lb x 4 and 30-40ft-lb x 2 radiator
      GW uses two small fender washers and Speed Tech use a large fender washer and a lock washer on the the radiator mounts, Fesler doesn't have any lock washers. I'm guessing the smaller diameter washer takes the place of the lock washer with the Feslers, which would go closest to the bolt head?
      Apr 2004
      OKC, OK
      Quote Originally Posted by 67rally View Post
      bolt,washer, male bushing through top of core support, female bushing between frame and core support, washer and nut in frame. Do not torque them down until front sheetmetal has been squared.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Jan 2011
      Boston, MA
      Quote Originally Posted by MuscleRodz View Post
      Thanks Mike (and thanks for the parts). I contacted Chris and he said he will send a copy of the instructions. My question was which washer goes where? There are two different sized washers for each front bushing.
      Apr 2004
      OKC, OK
      machined washer on top, or the left one in the pic
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Jan 2011
      Boston, MA
      Thanks Mike. I heard back from Chris Fesler as well. He recommended 35 lb-ft on the core supports and 80 lb-ft on the mid and rears. For future reference, here's a pic of the instructions.
