    Results 1 to 20 of 32
      Boonville, Missouri
      Daytime Running Lights with Turn Signals - Challenger / 69 Camaro
      A buddy of mine stopped by with his newly acquired Challenger and he wanted LED running lights installed. I think it looks slick.
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
      Jun 2006
      Kent
      Country Flag: UK
      Nice! :
      Boonville, Missouri
      How about a Cuda - Looking Angry!
      Oct 2005
      how do these work? They are whiteish/blue when in driving light mode and go to amber when the turn signal part gets power? What brand are they are and where did you purchase them from?
      Tom
      Dec 2007
      Wisconsin
      Quote Originally Posted by Bigblue73 View Post
      Those are really cool. Where can you get them... can the running lights be switched on or off?
      Boonville, Missouri
      I developed these for my car, a Dodge Challenger, since I always wondered why the Challengers never had fog lights. I wanted a day time running light that is multifunctional to also act as the turn signal. By multifunctional, the units have multiple LED arrays that change color to remain DOT compliant for front of vehicle illumination. The installation is all plug and play and uses the vehicles existing 1157 socket connection. The actuation is simply done by toggling the first position on the headlight switch, the parking lights. The once parking lights are now daytime running lights. A special circuit has been added to the LED arrays to switch between the white LED array and amber LED array and a set rate to act as the turn signal indicator. When the turn signal is cancelled the white LED array will remain illuminated. When the parking lights are not actuated the amber LED array acts as the regular amber turn signal bulb. Simple yet functional. Please watch the attached video for a better explanation.
      70 roadrunner lights video
      http://www.youtube.com/watch?v=fYUifopLkgs
      Illumin8s Applications (More in development – Please call with your application)
      Dodge Plymouth
      70 – 74 Challenger 71 Barracuda
      70 Charger 72-74 Barracuda
      68 – 69 Charger 70 Roadrunner
      Plymouth
      71 Barracuda
      72-74 Barracuda
      70 Roadrunner
      Ford Mercury
      64 ½ - 68 Mustang 67-68 Cougar
      69-70 Mustang
      Chevrolet
      67-69 Camaro (67-68 RS cars are in process)
      Street Rod – Custom Universal Kit.
      The product line is called Illumin8s and I have started selling these in kit form for the above listed applications. If you are interested please feel free to contact me or PM me here. I'm still associated with Hurst Driveline Conversions, however I am located in Missouri not in So-Cal.
      Illumin8s
      e-mail: [email protected]
      Cell: (573) 823-1813
      Columbia, Missouri
      www.globaloverdrive.com
      Boonville, Missouri
      I just finished these for the 67-68 Mustangs and Cougars. The LED arrays fit in really nice.
      Bright Day Time Running Lights
      From the back side.
      Boonville, Missouri
      For the 69 Camaro
      Good morning -
      Here are some shots of the LED arrays in '69 Camaro Lens. These are OEM factory lenses. I like the look.
      Marshall , MO
      I saw these in the Pink car in person, they look good.
      Brad Shepard
      69 Malibu
      Marshall, MO
      May 2009
      Florida
      Brilliant idea!
      Fernando
      1967 PT Camaro
      Project "N-XSS"
      https://www.pro-touring.com/forum/sh...ad.php?t=70712
      Cornettsville, ky
      will do to the skylark
      Boonville, Missouri
      I sent you a PM Nekkidhillbilly! Hey Brad - Sorry I missed you - Did you see Dwayne's car at the Steve McQueen show?
      Tony Edler
      Illumin8s
      Marshall , MO
      Sure did, he said you were at the lake show. I was hoping to make it to heritage days this year but looks like I will be in Norwalk OH at the rag races.
      Will these bulbs fit in a 69 Chevelle parking lamp housing? It is rectangular instead of round. I could get you a housing and lens for R&D if you want.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Boonville, Missouri
      I'll look for a Chevelle this weekend and check. Rick Ball is having a show to benefit the High School so I'll check out the iron there. If not I'll be in touch next week. The '69 Camaro lights turned out real nice and look incredible. Pictures soon.
      Marshall , MO
      When does the show start? I assume it is at the car lot. I may run over.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Cornettsville, ky
      hey your pms are full
      but the skylarks are rectangular not round
      Boonville, Missouri
      I've got a 69 Chevelle from Brad (Shep) and we'll see how they look. The fact that the LED's are round really doesn't have the effect that you think (a hot spot). The factory lens does a great job to muting or dispersing the light. I'll post some photos soon. I just hope they fit behind the lens!
      Feb 2011
      Dallas, TX
      so your product is a drop in replacement for an 1157 dual-filiment bulb, essentially. With a circuit for the turn signal. So the flasher in the OE fuse panel is retained or removed?
      Just trying to understand the need for a circuit, if the unit replaces an 1157 which is a 3-wire bulb, on, flash, ground and upgrade the flasher like normal LED upgrades.
      I must be missing something.
      Also Pm pricing on custom/street rod 1157 kit/pair please.
      Rob
      Boonville, Missouri
      You are correct - The LED array has an 1157 pigtail that plugs into the existing socket. Your stock wiring is retained as using a bulb. No modification. The only modification that may be required is the changing of the flasher module to a "No-Load" unit versus the stock bi-metal unit that works off resistance. I sent you a PM.
      Tony Edler
      Illumin8s
      Marshall , MO
      Hey Tony any progress on the chevelle lights.
      Brad Shepard
      69 Malibu
      Marshall, MO
