    Thread: best tire size
      Feb 2011
      best tire size
      Hi, all i,m new to the site, I have a 1970 nova and i,m wondering how much of a wheel and tire i can fit ?
      Welcome,,, hopefully some of the Nova dudes will step up and help.... Typically with a stock car in that era you will be able to get at least a 255 up front and a 275 out back with minimal modification. However, this all depends on the rim selection and how low your car is. I personally have never selected tires for a Nova, but have modified a 72 Nova to get 315's on all for corners.
      if you don't get an answer from one of the nova owners, then try taking your car to a tire dealer for some test fits.
      Good luck.
      Long Beach, Ca
      Brett is pretty much spot on. A 255/40/17 will fit up front so long as you remove the middle inner fender mounting bolt and flatten that spot out, I had a set on some 17x9 wheels with zero offset. In the rear you can fit a 275, but you will need to cut off your fender lip, not just fold it.
      I would get a hold of the guys at Driverz Inc, they have their tire fitments down.
      And as Brett said, you can make anything fit with a big enough hammer, or plasma cutter... I know.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
