02-19-2011 #1
Starting The Transformation
- Aug 2009
- Langley BC, Canada
- 264
fuel timing and higher compression???
As some may know I am getting new heads through an AFR warranty claim. My question is I am going from 9.5-9.7:1 compression to about 10.2:1, Do I need to adjust my timing from where it was at (35*) and or re jet the carb?
It was tuned on the dyno for the 9.5 ratio so I assume that was set up right but am not sure what the small bump in compression will do if anything.
Kevin Freund
1961 Impala Drop Top
