      Aug 2001
      Connecticut
      Front and Rear disc brake setups
      So, I'm doing a brake upgrade, I have a few parts for sale...
      Front spindles (magnafluxed) with remachined hubs, 1/2" wheel studs, c5 vette calipers, touring classics anodized aluminum brackets, 13" drilled and slotted rotors (or I have plain slotted if you'd prefer those), hawk hps pads $595 and that includes the spindles, hubs, and bearings. (does not include the steering arms or braided brake hose)
      Rear 12" brakes to match, uses 93-96 camaro calipers with built in emergency brakes (same as the c4 vette rears but the emergency brake works better with fixed axle cars), drilled/slotted rotors, hawk hps pads, and brackets for a ford 9" rear end (large bearing ford) $495
      or $995 for everything. I'll post pics over the weekend.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Feb 2010
      Central NJ
      pm sent
      Dec 2007
      Lombard, IL
      Is it safe to say this is for first gen camaro?
      Dan
      1971 Chevelle Maliboo Convertible 496/4L80E
      1956 210 2 door Sedan 8-71 blown 468/T400
      Aug 2001
      Connecticut
      Quote Originally Posted by Zanie View Post
      the rears will fit any large bearing ford 9", I might be able to fab up some 12 bolt brackets for them though.
      the fronts are on 67-69 camaro spindles but those are also used on 64-72 a-body (chevelle, 442, etc.) and 68-74 nova. (steering arms are different, spindles are the same) -Dan
      2006 Corvette Z06
      Aug 2001
      Connecticut
      pictures--- also I'll knock $100 off the fronts if you don't need the spindles.
Size:  149.1 KBName:  2011_MISC 038.JPG
      2006 Corvette Z06
      Long Beach, Ca
      If the brackets are for a disk spindle and you choose to seperate, let me know!
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Dec 2007
      Lombard, IL
      Crap! according to the Kore3 template the front brakes won't clear my Billet Specialties HiBoy Wheels. They are 17 inch. What a bite.
      The rears would be fine.
      Dan
      Aug 2001
      Connecticut
      sold sold sold. thanks to all.
      2006 Corvette Z06
