    Results 1 to 17 of 17
      Feb 2011
      Chicago
      New from chicago (Roy)
      I have been posting in the wrong part of the forum so a little about what i am been doing i have been putting a ls1 and a 4l60e also doing a four wheel disc conversion into my 1971 chevelle it seems to be more of a restoration than a conversion no really big rust spots or holes just alot of service rust and a **** load of dirt nothing a wire wheel and a mask can not take care of here are a couple of pics.
      Feb 2011
      Chicago
      I am still learning how to use this site sorry but it says i have used all my storage for pics so i had to delete some from my other thread if there is a way to get more storage i am all ears thanks here is a couple more pics
      Feb 2011
      Chicago
      ls1 swap
      I have removed the tank and the rear end i wired wheeled and put 2 coats of lizard skin on the bottom of the trunk i hope this will take some noise from the fuel pump! i even got my son to do some work lol!
      Feb 2011
      Chicago
      ls1 swap
      Well i got the tank and fuel line installed and also the rear end it has been a fun process i have been working on the car for the last couple of days after work and have got alot done!
      Feb 2011
      Chicago
      ls1 swap
      To bring me up to date on my project i have got the motor in the car i had a problem with the tierod end hitting my oil pan i put a 1/8 plate under the motor mount and lifted the engine just enough to clear it should be fine! next is the wiring!!!!
      Erie, PA
      Welcome neighbor, nice project!
      Andreas
      www.fgmcc.com
      Feb 2011
      Chicago
      ls1 swap
      I got all my stuff in,my wiring harness ,computer alt. pwr steering ac,from s&p the kit was pretty easy to install all detailed instructions i need to find out which fan set up to use not really sure yet i have been reading the forum and every body is running something different any suggestions Next to do on my list is to reinstall the front end!!
      good looking project!
      Feb 2011
      Chicago
      Austin, TX
      Looks Goooood! I dig that color gold.
      I'm about at the same place in my LS swap into my Camaro. You should come out to the INR autocross this summer & help me beat up on some Miatas!! http://www.inr-scca.org/
      Todd Longfellow
      Feb 2011
      Chicago
      Sounds like a plan!!
      Feb 2011
      Chicago
      Well i am getting close still need to do a few loose ends yet i have a couple more wires left i am working in a 2 1/2 garage so i need to get the car on the ground so i can get to the drivers side better here is a couple of pics to show what i have done!
      May 2006
      Deerfield, IL
      Looking good, what part of chicago you from?
      Feb 2011
      Chicago
      I am in the the bucktown area north&damen
      May 2009
      Florida
      I like where it's headed
      Fernando
      1967 PT Camaro
      Project "N-XSS"
      https://www.pro-touring.com/forum/sh...ad.php?t=70712
      Feb 2011
      Chicago
      Well i got it running this weekend i have having a problem with the ignition power to the fuse box I tried using a relay with direct power from the battery and it still would not start right i put the ignition wire straight to the battrey and it will start has any one had this problem I am using s&p harness and my computer is from a 98 camaro???
      Feb 2011
      Chicago
      I called s&p those guys know there stuff they told me the problem it was fixed in 5 minutes wow!! i need to bleed my brakes and put my wheels back on time to take it out!
