Results 1 to 12 of 12
Thread: Harder Brake Pedal?
02-14-2011 #1
- Apr 2009
- 25
Harder Brake Pedal?
Ok, so right now I have completed the 1le brake upgrade with Wilwood d52 calipers on my 71 Trans am and have the remaining stock drums. I want to convert to disk in the rear and will probably get the Right Stuff kit from summit. As of right now my brake pedal moves probably half way before any braking is done and you have to push it nearly to the floor to get the car to stop. I cannot lock up any of the tires with the pedal to the floor. Now with that said, I will be purchasing all new master cylinder, brake booster, and proportioning valve for a 80' trans am with disc/disc. Am I going to run into the same soft pedal/ travel issues I have now? Is there anyway to make sure I have immediate firm pedal pressure aka High and hard? Do I need a different size Master cylinder?
