      Apr 2010
      Littleton, CO
      98+ F Body Brake users check in. Quick Question
      Hey everyone. I'm doing the 98+ F Body Brakes on my 69 Nova. I just got the brackets from Rich Hoag (They're beautiful), and I need just to get diameter on the hubs turned down a bit.
      BUT, I need to know what size bolts people used to mount the caliper bracket to the spindle and the caliper to the caliper bracket.
      1969 Chevy Nova - complete rebuild
      Jan 2011
      Lawrence Ks.
      I am useing this same exact set up on my 67 camaro,but I made my own brackets. The upper bolt that mounts the bracket to the spindel is 5/8x28x1. As for the bolt that I used to bolt up the bracket,spindel,and the steering arm. I used the stock one, 1/2x2 1/2 fine thread. Found all at the local hardware store. Hope this helps you out.
      Oregon
      Quote Originally Posted by 396RSconvert View Post
      The upper mounting boss bolt is 5/8-18...I'm pretty sure the above is a typo. The steering arm bolts should be 1/2-20 and you want at least 2 threads sticking through the nut, so choose your length accordingly as it will vary based on your bracket thickness. I would suggest using Grade 8 hardware.
      Tobin
      KORE3
      It's what I does.
      Apr 2010
      Littleton, CO
      Thanks so much for the replies ... Gonna go get them tomorrow
      Jun 2011
      Camp Leatherneck, Afghanistan
      Hey I know I am the new guy here, but even after searching "F Body Caliper Brackets" in various forms, I am not finding anything on these things! Will they clear stock wheels (such as my AO rallyes??)? I am guessing not. What is Richard Hoag's username on here?
      KFD
      Kelly Doke
      1971 Skylark: '73 Buick 350-4v, '69 Chevelle Frame, '70 AO code Rallye Wheels
      2003 Aprilia RSV Mille: Tigcraft pipe, a few speeding tickets
      1983 Wife: Yep, that's her in my avatar
      Mountain Springs, Texas
      Quote Originally Posted by KFD View Post
      KFD
      zman1969
      1957 Buick Estate Wagon
      1959 Apache Fleetside
