      Feb 2011
      68 to 69 Rear quarter conversion?
      I have an all original really clean, nearly rust free Numbers matching 68 camaro 327/4speed convertible. I'm going to replace the trunk pan and rear quarters. Is it possible to use 69 quarters? Being a numbers matching car would that plus a mini tub devalue it at all? This is my first muscle car that hasn't been hacked up.
      Sean
      Jun 2006
      NW burbs IL
      I think it will make it harder to sell.
      Matt
      Phoenix
      I wouldn't think it would be desirable to most, certainly not to me personally
      Erik
      https://www.pro-touring.com/showthre...without-a-name
      Camaro LS2, T56, 12 bolt, C6 Z06 brakes, Rushforth Super Spokes, ATS Spindles
      2006 Chevy Trailblazer SS
      Dec 2009
      I wouldn't do it. It's either a 68 or a 69. Frankenstein's (no offense intended to you or your build) don't typically retain much value or market appeal.
      My .02
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Lawrenceburg, TN
      Do not do it!!!
      it will not (repeat Never) sell!
      69 quarters are wider and then then you have to replace the tail panel inner trunk structure gas tank, just as a start
      if you want a 69 then buy one and sell the 68 to another member who would want a 68
      Feb 2011
      68 quarters it is. What about the mini tub is that bad? What about dropping in an ls3/T56? Is that viewed as a negitive? Current engine is numbers matching 327/4speed 30 over with a little cam but still has factory carb and intake. obviously I would hang on to the original powertrain.
      Lawrenceburg, TN
      Mini tub is fine many owners would not mind such a thing and its not a noticable (or damaging) change
      Feb 2011
      Indianapolis,In.
      If you plan on keeping the car, build the car that you want. If you don't, don't change anything that can't be undone without much effort.Sit down, research & plan your build the best that you can. You will waste less money that way. Definately leave the 68 quarters.
