    Results 1 to 19 of 19
      Dec 2009
      Brunswick, GA
      67 Camaro Rear Suspension Question
      I've done a search and couldn't find the answer that I was looking for. I have a 67 camaro that I am doing a frame off restoration on. The car may never be raced on a track but I love a good performing ride that isn't too rough and that will still hook if I run it at the 1/8th mile. I'm want the best bang for the buck. Budget really doesn't matter if it is worth it. I know people will ask those questions so hopefully I've answered them. Now my question, the 67 has parallel shocks. Is it worth it because of the shocks on a 67 to g-bar or g-link it or is it ok to put on a set of hotchkis or dse leaf springs and go from there. I have installed DSE's mini tubs as well. I've thought about DSE springs with caltrec bars. Or possibly the g-link unit from Frank at Prodigy. Just looking for everybody's opinion. Thanks guys!
      Indiana
      Our AirBar has worked well at the strip on our Velocity Camaro and many others. It can be used with the ShockWaves our our new coilovers. Velocity ran fast dragstrip time at hte Run Through the Hill event a couple of years ago. I think it was a 7.96 1/8th mile time.
      http://www.ridetech.com/garage/1968-camaro-velocity/
      http://www.ridetech.com/store/suspen...r-systems.html
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      Jun 2009
      If you want bang for the buck it's really hard to beat a torque arm setup, especially when used for multi-purpose applications. Feature for feature, compare the following with other rear suspension designs:
      • Completely bolt-in design - no welding or fabrication needed. Some kits require major floorpan surgery while others require welding tabs. The BMR kit requires neither and simply bolts into place.
      • Bind-free articulating suspension via Delrin and spherical bearing bushed suspension links. A torque arm acts like a centrally located single "ladder bar". It counteracts axle counter-rotation like a ladder bar or traction bar while still allowing the rear suspension to articulate properly.
      • Adjustable ride height, adjustable pinion angle, adjustable roll center, adjustable instant center.
      • Kits available for 10 Bolt, 12 Bolt, and Ford 9" applications.
      • BMR uses a true Watts link to locate the rearend instead of a panhard bar. Mounted in double-shear fashion and machined from 6061 aluminum, the watts link pivots on fluted delrin bushings and connects via polyurethane and rod end link arms.
      • Powdercoat comes standard. Some kits are displayed powdercoated yet when purchased, it is an added cost.
      For more information, Images and pricing, visit our webpage HERE.
      Mar 2010
      The best bang for your buck is going to be Hotchkis drop leaf springs with caltrac bars. This will give the ability to hook up, but to be honest the ride isn't that great. We are upgrading our 1967 Firebird to the Prodigy 4-Link. If you want to save money I will sell you 3" drop Hotchkis leaf springs and QA1 shocks used, but in perfect shape for a great deal. If you don't like it you can always upgrade. If you have anymore questions send me a message.
      Dec 2009
      Brunswick, GA
      I have looked at the G-Link as well. I've thought about just using DSE springs but am worried about wheel hop with the shocks not being staggered. Just trying to get everybody's opinion and do research.
      Phoenix
      I can tell you I don't have any street driving experience with any of these suspensions but I have done some research. I changed my mind to a coil over suspension from leafs a little bit later in my project but if I was where you were at, I would do the Art Morrison rear 4-bar subframe that replaces the stock rear frame rails all together. I liked the idea of not attaching all that suspension stuff to those thin sheet metal frame rails not really designed for it in the first place. On the other hand, a lot of guys have been really hard on these suspensions with original frame rails with no problems.
      Erik
      https://www.pro-touring.com/showthre...without-a-name
      Camaro LS2, T56, 12 bolt, C6 Z06 brakes, Rushforth Super Spokes, ATS Spindles
      2006 Chevy Trailblazer SS
      Fredericksburg, VA.
      Quote Originally Posted by ErikLS2 View Post
      This is exactly what I was concerned about too. But as you said a lot of people have driven a lot of cars with the bolt on 4links with no problem. I'm still trying to decide between the Art Morrison 4link rear frame or the Prodigy 4link.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Mar 2010
      Alabama
      I am not trying to highjack the thread but I have a few questions. I have a 67 Camaro and I am looking to go with the Heidts setup for one it will do what I need and it is a cheaper than the others. Is it a good setup for the money and can you still run a stock style fuel tank with it?
      David Butler
      "If you're not first, you're last"
      67 Camaro Twin Turbo SBC (changing from Blow-thru to Holley HP EFI)
      Dec 2009
      Brunswick, GA
      I've heard that the ride quality is a lot worse with the hotchkis leaf springs than the detroit speed springs. Does anybody have any experience with this? I would also like to hear reviews of the tci and heidts 4 link.
      Mar 2010
      Alabama
      I like the way the BMR setup looks, will it work with a stock style gas tank? and whats price for setup above?
      David Butler
      Sep 2007
      Hampton Bays NY
      Quote Originally Posted by bret View Post
      Yup and I ran a 7.97 with the same suspension!
      Vinnie Allegretta
      A Winner Never Quits...A Quitter Never Wins
      www.fquick.com/vinz68
      Dec 2009
      Brunswick, GA
      What are the size dimensions for the tanks on the air ride suspension?
      Des Moines, IA
      You can find our tank options with dimensions here:
      http://www.ridetech.com/store/muscle...ures_hash=V220
      If you don't want to put it on air we now offer coil over options as well:
      http://www.ridetech.com/store/muscle...ers-musclecar/
      We are currently fitting all of our "vehicle specific" applications which are not yet on the web. If you are interested just call our sales staff and they can help you choose the correct components for your application.
      Mar 2010
      Alabama
      Will the BMR suspension work with stock style fuel tank.
      David Butler
      Jul 2009
      New Jersey
      I'll let BMR answer, but I called them and they told me yes. It was a big deciding factor between selling my leafs and going this route. Narrowed tank is expensive. If I didn't need to buy one, the BMR was a more attractive option. So I asked and they told me yes. Hope they are right cause I sold all my stuff today.
      RJ Cilurso
      67 Camaro with a few things bolted to it
      12 Camaro with a few things bolted to it
      50 Chevy 5 window p/u with a few things unbolted
      USAF
      Mar 2010
      Alabama
      Yeah I just puchased a glenns tank for my turbo setup and it was pricey so this could be a deciding factor for me as well. The BMR looks to be very nice.
      David Butler
      Mar 2010
      Alabama
      After looking and talking to a few people for the money the Heidts seems to be the way to go.
      David Butler
      alpine ca
      you should check out speed tech or at least call blake
      john
      BUILD LINK
      Jun 2009
      Quote Originally Posted by DButler View Post
      Yes, the torque arm setup works with the factory tank. You would only need a narrowed tank if you had mini-tubs installed with a 12" or 13" wide wheel. The deeper offset wheel crowds the exhaust routing and requires a narrowed tank to free up some room.
