      Aug 2009
      Help with Pictures on Your Fuel Line Routing at the Motor
      Getting going on some routing of the fuel lines at the motor and so far I have decided to mount a Y-Block along the frame and bring the two -6an fuel lines up to the back of the rails. From there, I will exit out the front of the rails into a regulator. Looking for some ideas in this department especially for Pontiacs...However, I welcome all suggestions from all brands.
      thanks in advance
      Sep 2007
      Denver
      if you are planning on doing a return line at the motor/regulator....do a search on here.
      David Beckstrom DVM
      So. Cal.
      Quote Originally Posted by old66tiger View Post
      thanks in advance
      That should work just fine. But I gotta ask? Why put the Y-block down lower away from the rails? Seems most fuel rails have the Y at the rails. What are the fuel rails from? Or did you make them? If you made them then you should be able to make the solid Y for the ends of the rails and just have one feed line coming up from the frame. And the exit? You said out the front of the rails. Just off one side right? Cause thats all you need. Dont need both rails returning fuel.
      But anyway, what you described will work. For a more sano look though Id place the Y-block on the back of the rails and just run one line up from the frame. JR
      What I write is opinion, none of it is factual. 2010
      Even though I'm conscious it doesn't mean I'm coherent. 2011
      I'm getting better with age. Best thing about old age is I don't know any better. 2012
